Can DNI still be disabled?
Starting with Quartus Pro version 23.3, it appears that DNI is now enabled by default. The --dni command line option appears to have no effect either way, and DNI is enabled regardless.
Is there still an option to disable DNI in Quartus Pro 23.3 and up? And if so, how?
-Roee
- roeekalinsky
Contributor
Intel support folks - Response, please?
-Roee
- BoonBengT_Altera
Moderator
Hi @roeekalinsky,
Thank you for posting in Intel community forum, hope all is well and apologies for the delayed in response.
Our engineer is checking on the mention clarification, and will get back to you at earlist.
Appreciate the patients.
Best Wishes
BB
- roeekalinsky
Contributor
Thank you, @BoonBengT_Altera . I'll look forward to hearing from you.
-Roee
- SyafieqS
I am checking this internally as there is no information regarding this
- SyafieqS
Might take sometimes for update as it is holiday season.
May I know how urgent this is?
- roeekalinsky
Contributor
Thank you for the update, @SyafieqS .
Will you be able to get answers in the next week or so, now that we're past the holidays?
The reason for my question is that I've found that DNI has introduced new bugs in Quartus Pro that break my existing flows. And as such, I'm currently unable to use newer versions of Quartus Pro (versions >=23.3) that appear to use DNI unconditionally.
For an example of such a bug, see:
Please let me know how long you think it'll take to get answers on this, so I can plan accordingly.
-Roee
- SyafieqS
Hi Roee,
I totally get it. Currently most of the team are on holiday thus expected slow in response. Perhaps you can come back in 1/2 week later? Is that okay?
I am following this case closely and will you know any update.
Does this issue total roadblock your development?
Possible to work on prior version for now?
- roeekalinsky
Contributor
Hi @SyafieqS .
Thanks for the update, I understand.
This is not currently blocking development. I am proceeding using an earlier version for now. But at some point this will gate customer releases of my IP if it can't support newer versions of Quartus.
So yes, a couple of weeks is okay, but hopefully not much longer than that.
Also, I'm hoping that Intel can get the above mentioned bug fixed in Quartus in time for the fix to make it into version 24.1. Can you share the timeline for that?
-Roee
- SyafieqS
Hi Roee,
I believe this initial issue to disable DNI might be related to https://community.intel.com/t5/Intel-Quartus-Prime-Software/Bug-Import-of-QDB-file-partition-fails-in-Quartus-Pro-versions/m-p/1554546#M80987
Regarding the disable of DNI, you are not encouraged to disable it. We want customers to run in DNI mode as much as possible. As mentioned in above issue. Yes this is a bug in DNI and I have provided some workaround and meantime waiting for patch release for affected version. Yes there is plan submitted for permanent fix in 24.1 as for now. I will put this to close pending as this is clear bug. We can remain communication in another case.
- roeekalinsky
Contributor
Thank you, @SyafieqS . I agree, we can close this thread, and continue further discussions at the other thread:
-Roee
- SyafieqS
I now transition this thread to community support. If you have a new question, Please login to https://supporttickets.intel.com/, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 5/5 survey
