Can DNI still be disabled?
Hi Roee,
I totally get it. Currently most of the team are on holiday thus expected slow in response. Perhaps you can come back in 1/2 week later? Is that okay?
I am following this case closely and will you know any update.
Does this issue total roadblock your development?
Possible to work on prior version for now?
Hi @SyafieqS .
Thanks for the update, I understand.
This is not currently blocking development. I am proceeding using an earlier version for now. But at some point this will gate customer releases of my IP if it can't support newer versions of Quartus.
So yes, a couple of weeks is okay, but hopefully not much longer than that.
Also, I'm hoping that Intel can get the above mentioned bug fixed in Quartus in time for the fix to make it into version 24.1. Can you share the timeline for that?
-Roee
