assign two clocks
I have a design with two clocks. The first one (named "clk") is correctly assigned in my sdc file with:create_clock -name "clk" -period 5.000ns but my second clock (named "clock2") is generating a warning. I've tried to add: create_clock -name "clock2" -period 40.000ns but I still have a warning. "clock2" is not a port, it's generated from "clk". How should I assign that? Thank you.13 Replies
You need to use 'create_generated_clock'.
See quartus help on create_generated_clock (http://quartushelp.altera.com/15.0/mergedprojects/tafs/tafs/tcl_pkg_sdc_ver_1.5_cmd_create_generated_clock.htm). Cheers, Alex - Altera_Forum
create_generated_clock -source [get_ports {clk}] <relationship to source> <target>
What structure in your design is creating clock2? If it's a PLL, you can use derive_pll_clocks to automatically create the generated clock. If not, you have to use create_generated_clock. - Altera_Forum
Thank you both but I still have another warning:
Warning (332060): Node: *|clock2 was determined to be a clock but was found without an associated clock assignment. Warning (332061): Virtual clock clock2 is never referenced in any input or output delay assignment. - Altera_Forum
--- Quote Start --- Warning (332060): Node: *|clock2 was determined to be a clock but was found without an associated clock assignment. --- Quote End --- Is related to the timing constrains not satisfied. --- Quote Start --- Warning (332061): Virtual clock clock2 is never referenced in any input or output delay assignment. --- Quote End --- Check that the virtual clock is not originally intended as non-virtual clock and specify the clock targets. Already addressed in previous thread. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation) - Altera_Forum
A virtual clock is created if you use create_clock and then don't set a target (an input clock port). It's used with set_input_delay or set_output_delay as the reference clock that drives the "upstream" or "downstream" device to/from the FPGA.
Post your updated sdc code. - Altera_Forum
Thank you both.
Please tell me exactly what I have to do. Here is my sdc code:#************************************************************ # THIS IS A WIZARD-GENERATED FILE. # # Version 13.1.0 Build 162 10/23/2013 SJ Full Version # # ************************************************************ # Copyright (C) 1991-2013 Altera Corporation # Your use of Altera Corporation's design tools, logic functions # and other software and tools, and its AMPP partner logic # functions, and any output files from any of the foregoing # (including device programming or simulation files), and any # associated documentation or information are expressly subject # to the terms and conditions of the Altera Program License # Subscription Agreement, Altera MegaCore Function License # Agreement, or other applicable license agreement, including, # without limitation, that your use is for the sole purpose of # programming logic devices manufactured by Altera and sold by # Altera or its authorized distributors. Please refer to the # applicable agreement for further details. # Clock constraints create_clock -name "clk" -period 5.000ns create_generated_clock -divide_by 8 -name clock2 -source # Automatically constrain PLL and other generated clocks derive_pll_clocks -create_base_clocks # Automatically calculate clock uncertainty to jitter and other effects. derive_clock_uncertainty # tsu/th constraints # tco constraints # tpd constraints - Altera_Forum
The two warnings (note they are not errors) are directly related. You're creating a virtual clock but then not referencing it with any input or output port delay setting - set_input_delay or set_output_delay as sstrell suggested.
Please note: it does not mean the timing constraint has not been satisfied, as suggested elsewhere in the thread. Post your updated constraints. Cheers, Alex - Altera_Forum
My sdc constraints are waiting for a moderator to agree...
--- Quote Start --- create_generated_clock -source [get_ports {clk}] <relationship to source> <target> What structure in your design is creating clock2? If it's a PLL, you can use derive_pll_clocks to automatically create the generated clock. If not, you have to use create_generated_clock. --- Quote End --- You need to answer this question before people can really help you. PLL? Did you try "derive_pll_clocks"? If the answer is yes to both these questions then you don't need the sdc constraints t for clock 2 at all (it is generated by "derive_pll_clocks") Obviously you don't have a 200MHz and 25MHz clock coming directly from the same clock pin? - Altera_Forum
You have not specified a target for your create_generated_clock constraint. That's why it's coming up as a virtual clock. If you are using a PLL, the target should be the output clock pin (get_pins) of the PLL, or just use derive_pll_clocks as mentioned.
