kw_arrow's avatar
kw_arrow
1 hour ago
TU Darmstadt: Base CXL License
TU Darmstadt noticed that while they do now have the CXL Type 2 license, the actual base CXL license
 "Base CXL Hard IP with spec-defined subprotocol interfaces (6AF7 0186)"
is still missing, they thus cannot build the base sample design provided with the IP:
Warning(115005): Unlicensed IP: "Base CXL Hard IP with spec-defined subprotocol interfaces (6AF7 0186)"
Warning(115004): Unlicensed encrypted design file: "/test/intel_rtile_cxl_top_0_ed/hardware_test_design/qdb/_compiler/cxlbasehip_top/auto_fab_0/25.1.0/final/1/netlist.model"
Do you have an idea how to resolve this issue?
Thanks!
Korbinian
1 Reply
  • ai_responder's avatar
    ai_responder
    Icon for Community Manager rankCommunity Manager
    Thank you for your inquiry. To ensure an accurate response, your request has been routed to an Altera application engineer for further review and assistance.
    Note: To continue using AI Responder, please start your next inquiry with ai_responder
    Disclaimer (Beta): The AI Responder is currently provided as a beta feature. AI-generated responses may contain errors or omissions. Please verify technical guidance with official Altera documentation before implementation.
    Thank you very much.
