8 years agoassign two clocks
Hi, I have a design with two clocks. The first one (named "clk") is correctly assigned in my sdc file with: create_clock -name "clk" -period 5.000ns but my second clock (named "clock2")...
8 years agoThe two warnings (note they are not errors) are directly related. You're creating a virtual clock but then not referencing it with any input or output port delay setting - set_input_delay or set_output_delay as sstrell suggested.
Please note: it does not mean the timing constraint has not been satisfied, as suggested elsewhere in the thread. Post your updated constraints. Cheers, Alex
