Another sld_hub error
I am trying to use NIOS 2 processor in max10 FPGA thus I've been unsuccesful. My project includes a NIOS 2 processor with parallel I/O controlling some LEDS.
This is the error I get when I try to compile the project:
Error (11176): Set_instance_parameter_value: There is no parameter named DESIGN_HASH on instance alt_sld_fab
Error (11176): Alt_sld_fab.: version not allowed for EModuleProperty, must be in {[DESCRIPTION, NAME, VERSION, MODULE_TCL_FILE, MODULE_DIRECTORY, INTERNAL, HIDE_FROM_SOPC, HIDE_FROM_QSYS, HIDE_FROM_QUARTUS, OPAQUE_ADDRESS_MAP, GROUP, AUTHOR, ICON_PATH, DISPLAY_NAME, DATASHEET_URL, TOP_LEVEL_HDL_FILE, TOP_LEVEL_HDL_MODULE, INSTANTIATE_IN_SYSTEM_MODULE, EDITABLE, VALIDATION_CALLBACK, EDITOR_CALLBACK, ELABORATION_CALLBACK, GENERATION_CALLBACK, COMPOSITION_CALLBACK, PARAMETER_UPGRADE_CALLBACK, OUTDATED_IP_FILE, ANALYZE_HDL, STATIC_TOP_LEVEL_MODULE_NAME, FIX_110_VIP_PATH, SUPPORTED_DEVICE_FAMILIES, REPORT_TO_TALKBACK, ALLOW_GREYBOX_GENERATION, SUPPRESS_WARNINGS, STRUCTURAL_COMPOSITION_CALLBACK, NATIVE_INTERPRETER, PREFERRED_SIMULATION_LANGUAGE, REPORT_HIERARCHY, UPGRADEABLE_FROM]}
Error (12154): Can't elaborate inferred hierarchy "sld_hub:auto_hub"
Error: Quartus Prime Analysis & Synthesis was unsuccessful. 3 errors, 4 warnings
Error: Peak virtual memory: 4931 megabytes
Error: Processing ended: Tue Jan 29 14:19:40 2019
Error: Elapsed time: 00:00:33
Error: Total CPU time (on all processors): 00:00:49
Error (293001): Quartus Prime Full Compilation was unsuccessful. 5 errors, 4 warnings
I googled this problem and found out similar forum threads, but nothing fixed my problem.
What should I do?
- Ahmed_H_Intel1
Sir, I am telling you that it isn't a project issue, it is a very simple design and must work. The errors shows that there is something went wrong in many and different points, it isn't specific, BTW, I will consult with the Quartus software team and will let you know. It is very weird to not be able to replicate your case, but don't worry I will do my best to find the root cause. Regards.- aakkü
I know it's not a project issue, it is obivous now because you can run it with no problem. It should be about my system or something. When you consult with the Quartus team can you please tell them that I run windows 10, tried reinstalling multiple times, tried different versions of quartus (16, 17,18) tried both versions of NIOS II, tried different examples from desing store containing NIOS II and I got the same errors in every single case. Maybe this has to do with windows 10?
- Ahmed_H_Intel1
I am using Windows 10 with Quartus 16.1 and 18.1 without any issue, I recommend you to check if the tool has a inflection with any other software and to disable the antivirus then reinstall the tool again.- aakkü
I'll try that and get back to you.
- aakkü
No matter how many times I try consistently get the same errors. I did what you told me to do and I get the same errors.
I've been trying the same thing over and over again, I don't know what to try next. What should I do now?
- yusufbas
I am getting exactly the same error, No matter what I try. I use quartus web 15.0, so not a licensing issue. Aakkü, have you solved the problem, what do you suggest? Is trying to solve this error a waste of time? Obviously I wont downgrade my windows 10 just for Quartus.
- aakkü
There doesn't seeem to be any solution. I believe it's waste time to try to solve the issue or ask for help in the forums, DO NOT TRY I almost gone mad. If you definitely need signal tap or NIOS microproccessor you are out of luck. The only help that you can find here is them saying " can you reinstall the tool" which obviously doesn't solve anything.
- yusufbas
Tried on my win10 may 2019 pc with Quartus Pro Lite 16.0, Haha the same error. I even tried enabling SignalTap II wit a .stp file, disabling and enabling SignalTap II, NO F LUCK. I suppose it will not work on Ubuntu too. Seems like Xilinx is better at every scenario haha.
