Another sld_hub error
I am getting exactly the same error, No matter what I try. I use quartus web 15.0, so not a licensing issue. Aakkü, have you solved the problem, what do you suggest? Is trying to solve this error a waste of time? Obviously I wont downgrade my windows 10 just for Quartus.
There doesn't seeem to be any solution. I believe it's waste time to try to solve the issue or ask for help in the forums, DO NOT TRY I almost gone mad. If you definitely need signal tap or NIOS microproccessor you are out of luck. The only help that you can find here is them saying " can you reinstall the tool" which obviously doesn't solve anything.
- yusufbas6 years ago
Tried on my win10 may 2019 pc with Quartus Pro Lite 16.0, Haha the same error. I even tried enabling SignalTap II wit a .stp file, disabling and enabling SignalTap II, NO F LUCK. I suppose it will not work on Ubuntu too. Seems like Xilinx is better at every scenario haha.
I have installed Ubuntu and then Quartus 19.1 & 16.0. It works. For Quartus 19.1, Nios2 EDS doesn't launch. The installation process was rather hard for me, so I will link those sites which helped me. I recommend dual booting linux and windows if you have space in your drive or if you have multiple drives.
Ultra helpful: https://wiki.archlinux.org/index.php/Altera_Design_Software
Very helpful: https://www-acc.gsi.de/wiki/Timing/QuartusInstallUbuntu1404.
Important: Check library dependencies at page 7 https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/manual/quartus_install.pdf
USBBlaster: https://www.intel.com/content/www/us/en/programmable/documentation/iga1446847781805.html#iga1447180976435
Nios2 EDS problem: https://forums.intel.com/s/question/0D50P00003yyRITSA2/the-eclipsenios2-wont-start
Thats pretty much it. Spent more than a week to get everything working (multiple times on different linux distros). These sites are like they are from heaven.
Oh no! One of the main reasons why I bought an FPGA dev board (DE10 Lite) was to build softcore cpu and mpu's, I was even thinking of designing one! There must be a solution, I mean embedded_guy got it working on win10, I couldn't in win10 and win7. Ill try Ubuntu. I hope it will work.
- aakkü6 years ago
Yes there are people (a lot of people) got it working on thier computer without any problem. However very few people get this spesific error and there seems to be no solution. If you get something working please let me know. Trying another OS is not an option with me, gotta stick with win 10.
Please keep me updated.
Tried on a win7 computer, still got the error with Quartus Web 15.0, Nios ii/f.... I am downloading Pro lite 16.0, and will update my PC to win10 may 2019 version. Windows Antivirus is turned off. I will keep you updated.
- aakkü6 years ago
I thought about switching vendors but I am already 6 months in the project switching vendors seems scary right now. Intel has a great FPGA product line, however there seems to be a lack of support. I hope they come up with something that actually works.
Kolay gelsin!
You won't believe but I installed Quartus 16.0 on a Windows 10 1803 pc, and it worked flawlessly! So I immediately copied the Quartus files, Quartus installer and the project I wrote to test on the computer. I am transfering the files to my computer which has Windows 10 1903, I hope it will work, and then I will share the files on drive, send you a link, and I hope everything will be fine again.
Size de kolay gelsin!
It didn't work.
- aakkü6 years ago
Congragulations I am glad you made it work and thank you for taking time to write an update about the progress you had.
Your other thread doesn't seem to have any useful suggestion other than redo everything all together.
Unfourtunately for me I can't switch to Ubunru or any other Linux type OS because I use other software in Windows and transporting all of them to Linux is just a big pain. I had to add a microconroller to my design just because I couldn't make NIOS working.
I guess I will not be using NIOS for a while. I wonder how Xilinx doing in Windows 10 :D
- burakduysak5 years ago
Try to change your OS language. That's helps for me
