aakkü
7 years agoAnother sld_hub error
Hello, I am trying to use NIOS 2 processor in max10 FPGA thus I've been unsuccesful. My project includes a NIOS 2 processor with parallel I/O controlling some LEDS. This is the error I get when I t...
Ahmed_H_Intel1
7 years agoSir,
I am telling you that it isn't a project issue, it is a very simple design and must work. The errors shows that there is something went wrong in many and different points, it isn't specific, BTW, I will consult with the Quartus software team and will let you know.
It is very weird to not be able to replicate your case, but don't worry I will do my best to find the root cause.
Regards.
- aakkü7 years ago
I know it's not a project issue, it is obivous now because you can run it with no problem. It should be about my system or something. When you consult with the Quartus team can you please tell them that I run windows 10, tried reinstalling multiple times, tried different versions of quartus (16, 17,18) tried both versions of NIOS II, tried different examples from desing store containing NIOS II and I got the same errors in every single case. Maybe this has to do with windows 10?
