Another sld_hub error
I am getting exactly the same error, No matter what I try. I use quartus web 15.0, so not a licensing issue. Aakkü, have you solved the problem, what do you suggest? Is trying to solve this error a waste of time? Obviously I wont downgrade my windows 10 just for Quartus.
- aakkü6 years ago
There doesn't seeem to be any solution. I believe it's waste time to try to solve the issue or ask for help in the forums, DO NOT TRY I almost gone mad. If you definitely need signal tap or NIOS microproccessor you are out of luck. The only help that you can find here is them saying " can you reinstall the tool" which obviously doesn't solve anything.
- yusufbas6 years ago
Tried on my win10 may 2019 pc with Quartus Pro Lite 16.0, Haha the same error. I even tried enabling SignalTap II wit a .stp file, disabling and enabling SignalTap II, NO F LUCK. I suppose it will not work on Ubuntu too. Seems like Xilinx is better at every scenario haha.
I have installed Ubuntu and then Quartus 19.1 & 16.0. It works. For Quartus 19.1, Nios2 EDS doesn't launch. The installation process was rather hard for me, so I will link those sites which helped me. I recommend dual booting linux and windows if you have space in your drive or if you have multiple drives.
Ultra helpful: https://wiki.archlinux.org/index.php/Altera_Design_Software
Very helpful: https://www-acc.gsi.de/wiki/Timing/QuartusInstallUbuntu1404.
Important: Check library dependencies at page 7 https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/manual/quartus_install.pdf
USBBlaster: https://www.intel.com/content/www/us/en/programmable/documentation/iga1446847781805.html#iga1447180976435
Nios2 EDS problem: https://forums.intel.com/s/question/0D50P00003yyRITSA2/the-eclipsenios2-wont-start
Thats pretty much it. Spent more than a week to get everything working (multiple times on different linux distros). These sites are like they are from heaven.
Oh no! One of the main reasons why I bought an FPGA dev board (DE10 Lite) was to build softcore cpu and mpu's, I was even thinking of designing one! There must be a solution, I mean embedded_guy got it working on win10, I couldn't in win10 and win7. Ill try Ubuntu. I hope it will work.
