aakkü
7 years agoAnother sld_hub error
Hello, I am trying to use NIOS 2 processor in max10 FPGA thus I've been unsuccesful. My project includes a NIOS 2 processor with parallel I/O controlling some LEDS. This is the error I get when I t...
aakkü
6 years agoThere doesn't seeem to be any solution. I believe it's waste time to try to solve the issue or ask for help in the forums, DO NOT TRY I almost gone mad. If you definitely need signal tap or NIOS microproccessor you are out of luck. The only help that you can find here is them saying " can you reinstall the tool" which obviously doesn't solve anything.
yusufbas
6 years agoTried on my win10 may 2019 pc with Quartus Pro Lite 16.0, Haha the same error. I even tried enabling SignalTap II wit a .stp file, disabling and enabling SignalTap II, NO F LUCK. I suppose it will not work on Ubuntu too. Seems like Xilinx is better at every scenario haha.
