21 years agoUART with FIFO Buffer
Need to use UART with FIFO Buffer in SOPC Builder Nios II System:
1> The UART RS232 available in SOPC are without FIFO is it possible to add FIFO by modifying the same UART core 2> If not is there any other SOPC ready UART_FIFO core available as free IP 3> If not is it possible to get estimate of - LE utilization without Modem Control logic - Is it necessary to write device driver for the same - Apprx how much design time it will take to design HDL UART, device driver for a single person? Please advice asap. running short of time. Thanks in Advance27 Replies
--- Quote Start --- originally posted by rau@Oct 24 2005, 09:16 AM need to use uart with fifo buffer in sopc builder nios ii system:1> the uart rs232 available in sopc are without fifo is it possible to add fifo by modifying the same uart core
2> if not is there any other sopc ready uart_fifo core available as free ip
3> if not is it possible to get estimate of
- le utilization without modem control logic
- is it necessary to write device driver for the same
- apprx how much design time it will take to
design hdl uart, device driver for a single person?
please advice asap. running short of time.
thanks in advance
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=10542)
--- quote end ---
--- Quote End --- Hi i think in sopc builder when we instantiate uart we get tab which asks for fifo size as it is in built. but i don't understand why u need another fifo for a uart.anyway i don't think it may be required. prasad
--- Quote Start --- originally posted by rau+oct 24 2005, 09:16 am--><div class='quotetop'>quote (rau @ oct 24 2005, 09:16 am)</div>--- quote start ---
1> the uart rs232 available in sopc are without fifo is it possible to add fifo by modifying the same uart core[/b]
--- quote end ---
that uart's code is generated on-the-fly by the sopc builder, so you could modify it, but it would be tricky, and you'd have to figure out a way to keep your changes from being overwritten when the sopc gets regenerated. good luck there.
--- quote start ---
--- quote end ---
not that i'm aware of. there are free cores, and cores that integrate with sopc builder, but not both.
--- quote start ---
--- quote end ---
usually the ip data sheet gives some clue to this.
--- quote start ---
--- quote end ---
maybe. assume it's going to need a driver unless you can find one out there already.
--- quote start ---
--- quote end ---
a while. this depends on many unmeasurable factors, so i couldn't give you a number. but it won't be easy.
<!--quotebegin-prasad_forums@Oct 26 2005, 01:03 AM i think in sopc builder when we instantiate uart
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=10579)
--- quote end ---
--- Quote End --- Really? I've never seen that. However, I've only used the Nios2 Altera UART, not any other core. Maybe you're thinking of the JTAG UART?
Hallo rau,
there is a free UART16550 core from OpenCores that can simply be implemented in a NIOS design and it is also not that problem to implement it into the SOPC Builder. All you have to do is to import the top level design file into the SOPC builder using the "Create new component feature" or to write your own bus wrapper to connect the WISHBONE bus to the AVALON. You will find this core here: opencores uart16550 (http://www.opencores.com/projects.cgi/web/uart16550/overview) More work has to be done to write some driver software for it. The register structure of this UART is also really simple so that it should only take a short time to bring something up to work. Best regards... Mschulz. - Altera_Forum
There is a uart with fifo which Altera sent me when I was having troubles with the standard uart speed. The file is ACF2002.zip which I am sure you can ask for from the service request people.
You need unzip it and add this whole directory to this location: <NiosII Installation Path>/components/. Then you can reopen the SOPC Builder to add this UART with fifo. It comes up as "cal uart". Good luck Ed- praveenkumar
please send the file to mail @[email protected]
dear Edmund,
Could you give the file ,thanks ,my email:[email protected] - Altera_Forum
Thanks for all the i/ps.
On my way to design UART with FIFO which will be included in Nios sys. In case of any difficulties/problems will keep coming back Thanks and Regards --- Quote Start --- originally posted by mike desimone+oct 27 2005, 12:44 am--><div class='quotetop'>quote (mike desimone @ oct 27 2005, 12:44 am)</div>--- quote start ---
--- quote start ---
--- quote end ---
--- quote start ---
--- quote end ---
--- quote start ---
--- quote end ---
--- quote start ---
--- quote end ---
--- quote start ---
--- quote end ---
--- quote end ---
--- Quote End --- Really? I've never seen that. However, I've only used the Nios2 Altera UART, not any other core. Maybe you're thinking of the JTAG UART? <div align='right'><{post_snapback}> (index.php?act=findpost&pid=10611)</div> [/b] --- Quote End ---
dear Edmund,
Could you give the file ,thanks you very much! my email: [email protected] Best Regards, feiwu - Altera_Forum
--- Quote Start --- originally posted by feiwu@Nov 23 2005, 01:19 PM dear edmund,could you give the file ,thanks you very much!
best regards,
feiwu
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=11105)
--- quote end ---
--- Quote End --- I have finished designing the UART having with FIFO without FIFO mode. the components/entities are as follows: Reciver State Machines - 1.write cycle 2.read cycle Receiver Shift Register, Receiver FIFO and data register Transmitter State Machines - 1.Write cycle for Data register and FIFO + Read cycle for Data 2.read cycle for FIFO 3.shifting data out Transmitter FIFO and data register, Receiver shift register Register Bank Register select logic and Baud rate generator I need a clarification: The Baud rate generator is generating a clock from the system clock. I am using baud clock for Transmitter shift register and transmitter state machine 3 for shifting data out rest all transmitter aoperation is on system clock i.e. TXFIFO uses single clock In RX logic baud clock is used for RXshift register to shift in the data and for the state machine that controls shifting in the data and writing to FIFO/data register ie. RX state machine 1 the RXFIFO and receiver state machine controlling the read cycle work on system clock. I need confirmation that ifthe way I am using baud clock and the system clock is correct? regards
Edmund
I also have the same problem. Could you please email it to [email protected] - Altera_Forum
Hallo Edmund,
is it also possible, that I can get the ZIP file for the FIFO UART? Thanks, M.Schulz.
