21 years agoUART with FIFO Buffer
Need to use UART with FIFO Buffer in SOPC Builder Nios II System: 1> The UART RS232 available in SOPC are without FIFO is it possible to add FIFO by modifying the same UART core 2> If not is ...
20 years agoThere is a uart with fifo which Altera sent me when I was having troubles with the standard uart speed. The file is ACF2002.zip which I am sure you can ask for from the service request people.
You need unzip it and add this whole directory to this location: <NiosII Installation Path>/components/. Then you can reopen the SOPC Builder to add this UART with fifo. It comes up as "cal uart". Good luck Ed- praveenkumar5 years ago
please send the file to mail @[email protected]
