21 years agoUART with FIFO Buffer
Need to use UART with FIFO Buffer in SOPC Builder Nios II System: 1> The UART RS232 available in SOPC are without FIFO is it possible to add FIFO by modifying the same UART core 2> If not is ...
21 years ago --- Quote Start --- originally posted by rau@Oct 24 2005, 09:16 AM need to use uart with fifo buffer in sopc builder nios ii system:
1> the uart rs232 available in sopc are without fifo is it possible to add fifo by modifying the same uart core
2> if not is there any other sopc ready uart_fifo core available as free ip
3> if not is it possible to get estimate of
- le utilization without modem control logic
- is it necessary to write device driver for the same
- apprx how much design time it will take to
design hdl uart, device driver for a single person?
please advice asap. running short of time.
thanks in advance
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=10542)
--- quote end ---
--- Quote End --- Hi i think in sopc builder when we instantiate uart we get tab which asks for fifo size as it is in built. but i don't understand why u need another fifo for a uart.anyway i don't think it may be required. prasad
