21 years agoUART with FIFO Buffer
Need to use UART with FIFO Buffer in SOPC Builder Nios II System: 1> The UART RS232 available in SOPC are without FIFO is it possible to add FIFO by modifying the same UART core 2> If not is ...
20 years ago --- Quote Start --- originally posted by feiwu@Nov 23 2005, 01:19 PM dear edmund,
could you give the file ,thanks you very much!
my email: [email protected]
best regards,
feiwu
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=11105)
--- quote end ---
--- Quote End --- I have finished designing the UART having with FIFO without FIFO mode. the components/entities are as follows: Reciver State Machines - 1.write cycle 2.read cycle Receiver Shift Register, Receiver FIFO and data register Transmitter State Machines - 1.Write cycle for Data register and FIFO + Read cycle for Data 2.read cycle for FIFO 3.shifting data out Transmitter FIFO and data register, Receiver shift register Register Bank Register select logic and Baud rate generator I need a clarification: The Baud rate generator is generating a clock from the system clock. I am using baud clock for Transmitter shift register and transmitter state machine 3 for shifting data out rest all transmitter aoperation is on system clock i.e. TXFIFO uses single clock In RX logic baud clock is used for RXshift register to shift in the data and for the state machine that controls shifting in the data and writing to FIFO/data register ie. RX state machine 1 the RXFIFO and receiver state machine controlling the read cycle work on system clock. I need confirmation that ifthe way I am using baud clock and the system clock is correct? regards
