21 years agoUART with FIFO Buffer
Need to use UART with FIFO Buffer in SOPC Builder Nios II System: 1> The UART RS232 available in SOPC are without FIFO is it possible to add FIFO by modifying the same UART core 2> If not is ...
20 years agoThanks for all the i/ps.
On my way to design UART with FIFO which will be included in Nios sys. In case of any difficulties/problems will keep coming back Thanks and Regards --- Quote Start --- originally posted by mike desimone+oct 27 2005, 12:44 am--><div class='quotetop'>quote (mike desimone @ oct 27 2005, 12:44 am)</div>--- quote start ---
--- quote start ---
originally posted by rau@oct 24 2005, 09:16 am
1> the uart rs232 available in sopc are without fifo is it possible to add fifo by modifying the same uart core
--- quote end ---
that uart's code is generated on-the-fly by the sopc builder, so you could modify it, but it would be tricky, and you'd have to figure out a way to keep your changes from being overwritten when the sopc gets regenerated. good luck there.
--- quote start ---
2> if not is there any other sopc ready uart_fifo core available as free ip
--- quote end ---
not that i'm aware of. there are free cores, and cores that integrate with sopc builder, but not both.
--- quote start ---
3> if not is it possible to get estimate of
- le utilization without modem control logic
--- quote end ---
usually the ip data sheet gives some clue to this.
--- quote start ---
- is it necessary to write device driver for the same
--- quote end ---
maybe. assume it's going to need a driver unless you can find one out there already.
--- quote start ---
- apprx how much design time it will take to
design hdl uart, device driver for a single person?
--- quote end ---
a while. this depends on many unmeasurable factors, so i couldn't give you a number. but it won't be easy.
<!--quotebegin-prasad_forums@Oct 26 2005, 01:03 AM i think in sopc builder when we instantiate uart
we get tab which asks for fifo size as it is in built.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=10579)
--- quote end ---
--- Quote End --- Really? I've never seen that. However, I've only used the Nios2 Altera UART, not any other core. Maybe you're thinking of the JTAG UART? <div align='right'><{post_snapback}> (index.php?act=findpost&pid=10611)</div> [/b] --- Quote End ---
