--- Quote Start --- We DMA from and adc data directly into a zero copy buffer and DMA straight out. We also use a HDL checksum component. --- Quote End --- In your case what is your best data rate? - Altera_Forum
--- Quote Start --- OK, so jumbo frame will change nothing. Work is to do in the software/driver part. I'm correct? --- Quote End --- Software, yes. Driver, not so much. A relatively small part of the time it takes to send a packet from an application is the time spent in driver code. - Altera_Forum
--- Quote Start --- The iniche stack does provide a zero copy interface. --- Quote End --- I don't suppose this works together with Linux system (the theme of this forum). Of course it should be possible to implement a dual NIOS system, one with niche, one with Linux. -Michael - Altera_Forum
I am also interested in knowing the results of how the performance changes with tcp zero_copy enabled. I am currently seeing no difference, so I am wondering if I have something else set that is disabling it.
jcnhal - Any chance you can post the difference in performance you are seeing? - Altera_Forum
--- Quote Start --- with tcp zero_copy enabled. I am currently seeing no difference, --- Quote End --- How did you "enable zero copy" with Linux ? I decently doubt that this is easily possible. You need to (1) port a zero-copy IP stack to NIOS and (2) create a zero-copy enabled Ethernet driver vor yo9ur hardware. -Michael - Altera_Forum
Sorry Michael, I was doing this in Windows with the 9.1 software...
I mixed two points of conversation and shouldn't have done that for confusion's sake and been a bit clearer. I am interested in just finding out the maximum performance using TCP that anyone has been able to achieve.
