16 years agoMaximum ethernet speed available with NiosII + Linux
Hello, I plane to built a system with a niosII mmu and linux on an Cyclone III device. I will use an IP ethernet core with an dp83848 phy. I need to use ethernet TCP communication. What is t...
16 years ago --- Quote Start --- OK, so jumbo frame will change nothing. Work is to do in the software/driver part. I'm correct? --- Quote End --- Software, yes. Driver, not so much. A relatively small part of the time it takes to send a packet from an application is the time spent in driver code.
