16 years agoMaximum ethernet speed available with NiosII + Linux
Hello, I plane to built a system with a niosII mmu and linux on an Cyclone III device. I will use an IP ethernet core with an dp83848 phy. I need to use ethernet TCP communication. What is t...
16 years ago --- Quote Start --- The iniche stack does provide a zero copy interface. --- Quote End --- I don't suppose this works together with Linux system (the theme of this forum). Of course it should be possible to implement a dual NIOS system, one with niche, one with Linux. -Michael
