16 years agoMaximum ethernet speed available with NiosII + Linux
Hello, I plane to built a system with a niosII mmu and linux on an Cyclone III device. I will use an IP ethernet core with an dp83848 phy. I need to use ethernet TCP communication. What is t...
16 years ago --- Quote Start --- with tcp zero_copy enabled. I am currently seeing no difference, --- Quote End --- How did you "enable zero copy" with Linux ? I decently doubt that this is easily possible. You need to (1) port a zero-copy IP stack to NIOS and (2) create a zero-copy enabled Ethernet driver vor yo9ur hardware. -Michael
