16 years agoMaximum ethernet speed available with NiosII + Linux
Hello, I plane to built a system with a niosII mmu and linux on an Cyclone III device. I will use an IP ethernet core with an dp83848 phy. I need to use ethernet TCP communication. What is t...
16 years agoI am also interested in knowing the results of how the performance changes with tcp zero_copy enabled. I am currently seeing no difference, so I am wondering if I have something else set that is disabling it.
jcnhal - Any chance you can post the difference in performance you are seeing?
