16 years agoMaximum ethernet speed available with NiosII + Linux
Hello, I plane to built a system with a niosII mmu and linux on an Cyclone III device. I will use an IP ethernet core with an dp83848 phy. I need to use ethernet TCP communication. What is t...
16 years ago --- Quote Start --- We DMA from and adc data directly into a zero copy buffer and DMA straight out. We also use a HDL checksum component. --- Quote End --- In your case what is your best data rate?
