10 years agoWhy I can't simulate Triple-Speed Ethernet MegaCore?
Hello community,
I hope for your help. I have 2 problems with simulation of Triple Speed Ethernet Megacore (TSE): Programming in VHDL with Quartus II 64-Bit Version 15.0.0 Build 145 04/22/2015 SJ Web Edition Simulation with ModelSim ALTERA STARTER EDITION 10.3d TSE is generated with MegaWizard, Example Design is also generated problem 1: tse doesn't seem to be bounded correctly in test bench - i want to simulate read and write over SPI from/to the registers of TSE (later of course I will simulate some other functions of TSE) - NativeLink and a test bench with the file TSE_MegaCore.vhd (my variation from the TSE) from the directory TSE_MegaCore is used - Tools -> Run Simulation Tool -> Gate Level Simulation... - Signal reg_busy stays on initial value, but TSE registers are addressed, data is writen to reg_data_in and signal reg_wr (or reg_rd) is set to '1' - register of TSE are not showed under Memory List in Model Sim - Warning ModelSim/Transcript: # ** Warning: (vsim-3473) Component instance "i_tse_mac : altera_eth_tse_mac" is not bound. # Time: 0 ps Iteration: 0 Instance: /test_spi/ZuTestendesModul/TRIPLE_SPEED_ETHERNET_MEGACORE File: C:/Users/matthiask/Masterarbeit/FPGA_Ethernet_Funktion/FPGA_Ethernet_Funktion/TSE_MegaCore_sim/TSE_MegaCore.vhd # ** Warning: (vsim-8684) No drivers exist on out port /test_spi/ZuTestendesModul/TRIPLE_SPEED_ETHERNET_MEGACORE/reg_data_out, and its initial value is not used. # # Therefore, simulation behavior may occur that is not in compliance with # # the VHDL standard as the initial values come from the base signal /test_spi/ZuTestendesModul/sv32TSERegisterDatenAnSPI. # # ** Warning: (vsim-8684) No drivers exist on out port /test_spi/ZuTestendesModul/TRIPLE_SPEED_ETHERNET_MEGACORE/reg_busy, and its initial value is not used. # # Therefore, simulation behavior may occur that is not in compliance with # # the VHDL standard as the initial values come from the base signal /test_spi/ZuTestendesModul/sTSERegisterbeschaeftigt. # # ** Warning: (vsim-8684) No drivers exist on out port /test_spi/ZuTestendesModul/TRIPLE_SPEED_ETHERNET_MEGACORE/eth_mode, and its initial value is not used. and so on. What's the Problem? Which files I have further to add to the testbench? Or are wrong settings the problem? problem 2: simulating test bench after ,,triple-speed ethernet megacore function user guide'', chapter 10, fails - launching Quartus II, open project generate_sim.qpf from directory TSE_MegaCore_testbench - on the Tools menu, I select Tcl Scripts and select the generate_sim_vhld.tcl file and I clicked run - message ,,Tcl Script File C:/Users.../generate_sim_vhdl.tcl executed'' - in directory Project/testbench_vhdl/TSE_MegaCore run_TSE_MegaCore_tb.tcl selected and executed - message ,,Tcl Script File C:/Users.../run_TSE_MegaCore_tb.tcl executed'' and now? - I want to start ModelSim: Tools -> Run Simulation Tool -> Gate Level Simulation... - message ,,Can't find file C:/Users/.../TSE_MegaCore_testbench/generate_sim.sft. Run the EDA Netlist Writer'' - I startet the EDA Netlist Writer - after a few seconds error massages: Error (12007): Top-level design entity "generate_sim" is undefined Error: Quartus II 64-Bit Analysis & Synthesis was unsuccessful. 1 error, 1 warning Error: Peak virtual memory: 670 megabytes Error: Processing ended: Fri Jan 29 10:13:05 2016 Error: Elapsed time: 00:00:12 Error: Total CPU time (on all processors): 00:00:26 Error (293001): Quartus II Flow was unsuccessful. 3 errors, 1 warning - why there isn't in the project a file named generate_sim (generate_sim.vhd?) ? are my own VHDL project and the testbench provided with the Triple-Speed Ethernet MegaCore independent from each other? so: how I can simulate the Triple-Speed Ethernet MegaCore? Greetings, Matthew5 Replies
Hi community,
maybe the TSE is a special component, what is not often used, but what about PLLs? I haven't solved the problem with the TSE, but I have to go further, so I implemented a very simple PLL (Altera PLL from the IP catalog in Quartus II, not from Qsys). Look, I got this Warning, when I wanted to start ModelSim # ** Warning: (vsim-3473) Component instance "i_tse_mac : altera_eth_tse_mac" is not bound. # Time: 0 ps Iteration: 0 Instance: /test_spi/ZuTestendesModul/TRIPLE_SPEED_ETHERNET_MEGACORE File: C:/Users/.../FPGA_Ethernet_Funktion/FPGA_Ethernet_Funktion/TSE_MegaCore_sim/TSE_MegaCore.vhd # ** Warning: (vsim-3473) Component instance "meine_pll_inst : Meine_PLL_0002" is not bound. # Time: 0 ps Iteration: 0 Instance: /test_spi/ZuTestendesModul/TAKT_GENERATOR File: C:/Users/.../FPGA_Ethernet_Funktion/FPGA_Ethernet_Funktion/Meine_PLL.vhd # ** Warning: (vsim-8684) No drivers exist on out port /test_spi/ZuTestendesModul/TRIPLE_SPEED_ETHERNET_MEGACORE/reg_data_out, and its initial value is not used. # # Therefore, simulation behavior may occur that is not in compliance with # # the VHDL standard as the initial values come from the base signal /test_spi/ZuTestendesModul/sv32TSERegisterDatenAnSPI. # # ** Warning: (vsim-8684) No drivers exist on out port /test_spi/ZuTestendesModul/TRIPLE_SPEED_ETHERNET_MEGACORE/reg_busy, and its initial value is not used. # # Therefore, simulation behavior may occur that is not in compliance with # # the VHDL standard as the initial values come from the base signal /test_spi/ZuTestendesModul/sTSERegisterbeschaeftigt. # # ** Warning: (vsim-8684) No drivers exist on out port /test_spi/ZuTestendesModul/TRIPLE_SPEED_ETHERNET_MEGACORE/eth_mode, and its initial value is not used. # # Therefore, simulation behavior may occur that is not in compliance with # # the VHDL standard as the initial values come from the base signal /test_spi/ZuTestendesModul/sTSEEthMode. etc. For TSE and the PLL the same warning. So I think, this couldn't be a TSE specific problem. I can simulate my registers, my spi, my RAM. but I can't get any signals from the TSE or the PLL (I still just want to write to the TSE registers; I haven't connected every signal in the port map of TSE, just the ones I think I need to have access to the registers). I still use NativeLink and have added TSE_MegaCore_sim/TSE_MegaCore.vhd and Meine_PLL.vhd to my test bench. So, what have I forgotten? Where's the failure? What I'm doing wrong? I would be lucky, if you can help me to simulate my whole system. Greetings, Matthew - Altera_Forum
Gate level simulation isn't supported on some devices, and this may be part of your problem.
Do you have the same difficulty with RTL simulation? - Altera_Forum
Hi ted,
from Quartus II I started ,,RTL simulation''. ModelSim generates a very long compilation report, unfortunately with an error: ... # vsim -t 1ps -L altera -L lpm -L sgate -L altera_mf -L altera_lnsim -L cyclonev -L cyclonev_ver -L cyclonev_hssi_ver -L cyclonev_pcie_hip_ver -L rtl_work -L work -L Meine_PLL -L i_tse_mac -voptargs="+acc" Test_SPI # vsim -gui "+altera" -l msim_transcript -do "Ethernet_Modul_run_msim_rtl_vhdl.do" # Start time: 11:43:12 on Feb 17,2016 # Loading std.standard # Loading std.textio(body) # Loading ieee.std_logic_1164(body) # Loading ieee.std_logic_arith(body) # Loading ieee.std_logic_unsigned(body) # Loading work.test_spi(test_spi_verhalten) # Loading work.fpga_register_allgemein(body) # Loading work.ethernet_modul(ethernet_funktion) # Loading work.spi_schnittstelle_synchron(behavioral) # Loading ieee.numeric_std(body) # Loading work.verdrahtete_logik(body) # Loading work.fpga_register_funktion(verhalten_register_funktion) # Loading altera_mf.altera_mf_components # Loading work.onchipmemoryram(syn) # Loading altera_mf.altera_common_conversion(body) # Loading altera_mf.altera_device_families(body) # Loading altera_mf.altsyncram(translated) # Loading work.tse_megacore(rtl) # ** Fatal: Error occurred in protected context. # Time: 0 ps Iteration: 0 Protected: /test_spi/ZuTestendesModul/TRIPLE_SPEED_ETHERNET_MEGACORE/i_tse_mac/genblk8/U_RGMII/the_rgmii_in4 File: nofile # FATAL ERROR while loading design # Error loading design # Error: Error loading design # Pausing macro execution # MACRO ./Ethernet_Modul_run_msim_rtl_vhdl.do PAUSED at line 154 Okay, this looks like you're right. (But I don't get any messages like that when I start ,,Gate Level Simulation''.) But what about the PLL? This component is used by many engeneers, students and so on. I can't really imagine, ModelSim isn't able to simulate these cores. Back to my old problem: I can't correct read (and maybe write) to the TSE registers. Here an example: I just want to read the TSE registers. I do a hardware reset and then in register 0x11 of the TSE there have to be the data 0xFFFF. But I read 0x482 or nonsense like that. I use the same code to write and read to On-Chip Memory RAM and it works. Kind regards, Matthew - Altera_Forum
I have solved Problem 2: simulating test bench after ,,Triple-Speed Ethernet MegaCore Function User Guide'', Chapter 10: - launching Quartus II, open project generate_sim.qpf from directory TSE_MegaCore_testbench - on the Tools menu, I select Tcl Scripts and select the generate_sim_vhld.tcl file and I clicked run - message ,,Tcl Script File C:/Users.../generate_sim_vhdl.tcl executed'' and then I have to start ModelSim from the desktop (not from Quartus - this causes an error), navigating in the Transcript window to the folder, where is run_TSE_MegaCore_tb.tcl stored (C:\Users\...\FPGA_Ethernet_Funktion\FPGA_Ethernet_Funktion\TSE_MegaCore_testbench\testbench_vhdl\TSE_MegaCore, type ,,cd'' for changing directory, type ,,dir'' to see the directories and files of the current folder) and type ,,do run_TSE_MegaCore_tb.tcl'' in the transcript window. Compilation of needed files is done automatic and simulation works fine! Greetings, Matthew - Altera_Forum
TO_BE_DONE
