10 years agoWhy I can't simulate Triple-Speed Ethernet MegaCore?
Hello community, I hope for your help. I have 2 problems with simulation of Triple Speed Ethernet Megacore (TSE): Programming in VHDL with Quartus II 64-Bit Version 15.0.0 Build 145 04/2...
10 years agoHi community,
maybe the TSE is a special component, what is not often used, but what about PLLs? I haven't solved the problem with the TSE, but I have to go further, so I implemented a very simple PLL (Altera PLL from the IP catalog in Quartus II, not from Qsys). Look, I got this Warning, when I wanted to start ModelSim # ** Warning: (vsim-3473) Component instance "i_tse_mac : altera_eth_tse_mac" is not bound. # Time: 0 ps Iteration: 0 Instance: /test_spi/ZuTestendesModul/TRIPLE_SPEED_ETHERNET_MEGACORE File: C:/Users/.../FPGA_Ethernet_Funktion/FPGA_Ethernet_Funktion/TSE_MegaCore_sim/TSE_MegaCore.vhd # ** Warning: (vsim-3473) Component instance "meine_pll_inst : Meine_PLL_0002" is not bound. # Time: 0 ps Iteration: 0 Instance: /test_spi/ZuTestendesModul/TAKT_GENERATOR File: C:/Users/.../FPGA_Ethernet_Funktion/FPGA_Ethernet_Funktion/Meine_PLL.vhd # ** Warning: (vsim-8684) No drivers exist on out port /test_spi/ZuTestendesModul/TRIPLE_SPEED_ETHERNET_MEGACORE/reg_data_out, and its initial value is not used. # # Therefore, simulation behavior may occur that is not in compliance with # # the VHDL standard as the initial values come from the base signal /test_spi/ZuTestendesModul/sv32TSERegisterDatenAnSPI. # # ** Warning: (vsim-8684) No drivers exist on out port /test_spi/ZuTestendesModul/TRIPLE_SPEED_ETHERNET_MEGACORE/reg_busy, and its initial value is not used. # # Therefore, simulation behavior may occur that is not in compliance with # # the VHDL standard as the initial values come from the base signal /test_spi/ZuTestendesModul/sTSERegisterbeschaeftigt. # # ** Warning: (vsim-8684) No drivers exist on out port /test_spi/ZuTestendesModul/TRIPLE_SPEED_ETHERNET_MEGACORE/eth_mode, and its initial value is not used. # # Therefore, simulation behavior may occur that is not in compliance with # # the VHDL standard as the initial values come from the base signal /test_spi/ZuTestendesModul/sTSEEthMode. etc. For TSE and the PLL the same warning. So I think, this couldn't be a TSE specific problem. I can simulate my registers, my spi, my RAM. but I can't get any signals from the TSE or the PLL (I still just want to write to the TSE registers; I haven't connected every signal in the port map of TSE, just the ones I think I need to have access to the registers). I still use NativeLink and have added TSE_MegaCore_sim/TSE_MegaCore.vhd and Meine_PLL.vhd to my test bench. So, what have I forgotten? Where's the failure? What I'm doing wrong? I would be lucky, if you can help me to simulate my whole system. Greetings, Matthew
