16 years ago
Verilog module Instantiation
Don't really know whether i should post this Q here or not.
I'm a student using modelsimSE 6.1f.
actually this Q is more to verilog...not on fpga hardware issue
i was wondering,how can i control the input to an instantiated module?
e.g:
module bin2bcdAdder(input1,input2,bcd);
full_adder fa1(input1,input2,SUM,carryOut);
endmodule
the testbench generates 0000 to 1111 into the module bin2bcdAdder
how can i control the input only from 0000 to 1001 can be passed to the instantiated module full_adder?
and i'm trully sorry if i post this Q in the wrong section, or altera forum is only allowing altera's hardware related Q
    You basicaly need to add soething like this somewhere in your code
    if (input == 1001) begin
    input <= 4'b0;
    end
    But I guess you have no clue where to add it right ?
    Well, I can not help you there, not without the code.
    input  input1,input2;
    output  bcd;
    wire  S;
    wire  input1,input2; /*without this line, i can't assign the input values to A1,B1 and compile the code*/
    reg  A1,B1;
    addminus4bit am4b(A1,B1,0,S,V,C);
    always @ (A,B)
    begin
    if(A>1001|B>1001)
    begin
    A1=4'b0;
    B1=4'b0;
    end
    else
    begin
    A1=input1;
    B1=input2;
    end
    /*some codes here*/
    end
    endmodule
    well,i tried using the always block...
    or is it useless to use the > comparison?
    do i need to do case for each bit from 0000 to 1001?
       output  bcd;
      wire  S;
       reg  A1,B1;
    always @ (A,B) // without a clock input this will NEVER work
    begin
    if((A>4'b1001)|(B>4'b1001))
    begin
       A1<=4'b0;  // proper assigments
       B1<=4'b0;  //proper assigments
    end
    else
    begin
       A1<=input1;  // proper assigments
       B1<=input2;  // proper assigments
    end
    /*some codes here*/
    end
    endmodule
    --- Quote Start ---
       output  bcd;
      wire  S;
       reg  A1,B1;
    begin
    begin
    end
    else
    begin
    end
    /*some codes here*/
    end
    endmodule
    --- Quote End ---
    not all always block needs a clock rite?may i know why do i need a clock pulse for this one?
    btw,it's all working now...tq^^
    added A1 and B1 to the output port to simulate it and it runs well
    without the clock generation
    I am getting error while instantiating modules on condition with the default module. it is giving error if i instantiate default mode.
    the code is much similar to this:
    module top(//parameters);
    addition u0(//parameters passing); line 2
    'ifdef(flag)
    sum u1(//passing the parameters);
    'else
    subtract u2(//passing the parameters);
    'endif
    endmodule
    if the module addition-u0 is removed, then only code is working properly. but i need to operate before conditional execution.
    plz help me.:cry:
