16 years agoVerilog module Instantiation
Don't really know whether i should post this Q here or not. I'm a student using modelsimSE 6.1f. actually this Q is more to verilog...not on fpga hardware issue i was wondering,how can i...
16 years agomodule bin2bcdAdder(input1,input2,bcd);
input input1,input2;
output bcd;
wire S;
wire input1,input2; /*without this line, i can't assign the input values to A1,B1 and compile the code*/
reg A1,B1;
addminus4bit am4b(A1,B1,0,S,V,C);
always @ (A,B)
begin
if(A>1001|B>1001)
begin
A1=4'b0;
B1=4'b0;
end
else
begin
A1=input1;
B1=input2;
end
/*some codes here*/
end
endmodulewell,i tried using the always block... or is it useless to use the > comparison? do i need to do case for each bit from 0000 to 1001?
