MaxNil's avatar
MaxNil
6 months ago
F-Tile Ethernet Hard IP (100G)
We are using the "F-Tile Ethernet Hard IP" (rev 15.0.0) in 100GE-4 + FEC mode in an Agilex 7 since >1 year, and it has worked fine when we build it with Quartus 24.2, but now after upgrading to Quartus 25.3.1 (patch 1.02) our 100G Ethernet switch no longer gets a link to the FPGA.
I have re-generated the"F-Tile Ethernet Hard IP" (rev 20.1.0) in Q25.3.1 with exactly the same settings (not using 'Advanced mode') as we had when generating it in Q24.2
One difference I see in the *.ip files is this:
rev 15.0.0: CUSTOM_RATE_GUI 25.78125
rev 20.1.0: CUSTOM_RATE_GUI 10.3125
These settings are not visible when not running 'Advanced mode'
Is there anyone else that has seen problems with this IP after upgrading to Q25.3.1?
A side note, we are also using the IP in 400GE-4 mode, and that works fine both in Q24.2 and Q25.3.1
  • Hello Max,
    Good day to you.
    Apologies for the delayed response as I was in tight schedule.
    May I know what is the patch 1.02 about?
    Pavee
  • Hello Max,
    We didn't hear from you since last update. If you have a new question, feel free to open a new thread to get the support from Altera experts.
    Thank you.
