14 years ago
TSEMAC SW reset bit never cleared CIII+KSZ9021GQ
Hi!
I have my board with CYCIII + 2 PHY KSZ9021GQ.
During debugging web_server under NIOS i have error out
"TSEMAC SW reset bit never cleared!".
And correspondingly does not start web-server (no web-server in browser).
Who encountered a similar error?
Log start:
InterNiche Portable TCP/IP, v3.1
Copyright 1996-2008 by InterNiche Technologies. All rights reserved.
prep_tse_mac 0
Your Ethernet MAC address is 11:22:33:44:55:66
Static IP Address is 192.168.3.250
prepped 1 interface, initializing...
[tse_mac_init]
INFO : TSE MAC 0 found at address 0x04002000
INFO : PHY Micrel KSZ9021GQ found at PHY address 0x1f of MAC Group[0]
INFO : PHY[0.0] - Automatically mapped to tse_mac_device[0]
INFO : PHY[0.0] - Restart Auto-Negotiation, checking PHY link...
INFO : PHY[0.0] - Auto-Negotiation PASSED
INFO : PHY[0.0] - Checking link...
INFO : PHY[0.0] - Link established
INFO : PHY[0.0] - Speed = 100, Duplex = Full
OK, x=10002, CMD_CONFIG=0x00002000
MAC post-initialization: CMD_CONFIG=0x04000200
[tse_sgdma_read_init] RX descriptor chain desc (1 depth) created
mctest init called
IP address of et1 : 192.168.3.250
Created "Inet main" task (Prio: 2)
Created "clock tick" task (Prio: 3)
Created "web server" task (Prio: 4)
Web Server starting up :(
Signals on MII - input to TSE:
https://www.alteraforum.com/forum/attachment.php?attachmentid=5148
Signals on TSE - output from FIFO of TSE:
RX
https://www.alteraforum.com/forum/attachment.php?attachmentid=5149
TX
https://www.alteraforum.com/forum/attachment.php?attachmentid=5150
    SW_RESET in Command_Config Register.
    Software reset. Set this bit to 1 to trigger a software reset.
    The MAC function clears this bit when it completes the software reset sequence.
    When reset is triggered, the MAC function completes the current
    transmission or reception, and subsequently disables the transmit and
    receive logic, flushes the receive FIFO buffer, and resets the statistics
    counters.
    Why SW reset bit never cleared?
    If that description is correct, I don't think it is valid to wait for it to be cleared.
    The clock on the MII interface is generated by the PHY, and its speed depends on the negotiated link speed. In the absence of a cable (etc) this clock is very likely to be stopped - so the current rx/tx can never complete.
    You either need some more robust 'hardware reset', or be willing to leave the MAC unit 'in reset' until the PHY has finished negotiating the link speed (etc) with its peer.
    Last log in Debug:
    prep_tse_mac 0
    [tse_mac_init]
    TSEMAC aFramesTransmittedOK=0x00000000
    TSEMAC aFramesReceivedOK=0x00000000
    TSEMAC aFrameCheckSequenceErrors=0x00000000
    TSEMAC aAlignmentErrors=0x00000000
    TSEMAC aOctetsTransmittedOK=0x40021e0
    TSEMAC aOctetsReceivedOK=0x040021f0
    TSEMAC aTxPAUSEMACCtrlFrames=0x04002200
    TSEMAC aRxPAUSEMACCtrlFrames=0x04002210
    TSEMAC ifInErrors=0x04002220
    TSEMAC ifOutErrors=0x04002230
    TSEMAC CMD_CONFIG=0x00002000
    mctest init called
    This is Statistics Counters (Byte Offset 0x060 – 0x0E0) of TSE
    Hm, nothing special here... Check differences in MDIO registers between 88E1111 and KSZ9021. E.g. check if software reset bit is in the same place?
    P.S. I suppose ethernet is not working right?
    --- Quote Start ---
    --- Quote End ---
    Hm, i think software reset it is register of TSE IP?
    Embedded Peripherals IP
    User Guide
    Table 25–7. Control Register
    SW_RESET
    Software can reset the core by writing to this bit twice. Upon the
    second write, the core is reset. The logic which sequences the
    software reset process then resets itself automatically.
    Executing a software reset when a DMA transfer is active may
    result in permanent bus lockup until the next system reset.
    Hence, Altera recommends that you use the software reset as
    your last resort.
    Hi all,
    i am sorry, i didnot read all discussion, but i have question.
    Is possible to use Micrel KZS9021RL/RN or KSZ9021GQ with Tripple speed ethernet driver or Igor MAC driver in uClinux ?
    I found that i am not possible to buy anywhere Marvell 88e1111. Now i use with success PHY DP83848 with Igor MAC IP with uClinux, but my colleague want to try gigabit phy.
    Thank you for your answer.
    Jan Naceradsky
    Having a quick look at the product brief, this PHY should work with the TSE mac. But you will probably need to modify the driver to add a profile with the correct MDIO registers and functions in order to support it.
    Okay, but i havent any experiences with repairing driver for uclinux, maybe it will take me one man-year:)) and my boss will be ungry:).
    Which PHYs use after marvel 88e1111 ?
    I'm not familiar with the uClinux drivers. But if you have a look at the driver code, you should find somewhere a list of the supported PHYs.
    For the uCOS / Interniche drivers, you will find them in the alt_tse_phy_add_profile_default() function in altera/*/ip/altera/triple_speed_ethernet/lib/sopc_builder/altera_triple_speed_ethernet/HAL/src/altera_avalon_tse.c . On my installed version (11.1) here is the list I have:
    [list][*]Marvell 88E1111[*]Marvell 88E1145[*]National DP83865[*]National DP83848C[/list]
    The National DP83865 is a gigabit PHY, but you should check first whether support for the PHY has been ported to the uCLinux driver. Or maybe uCLinux has a unified PHY driver architecture, independent from the MAC driver? If a uClinux specialist is around...
