14 years agoTSEMAC SW reset bit never cleared CIII+KSZ9021GQ
Hi! I have my board with CYCIII + 2 PHY KSZ9021GQ. During debugging web_server under NIOS i have error out "TSEMAC SW reset bit never cleared!". And correspondingly does not start web...
13 years agoI'm not familiar with the uClinux drivers. But if you have a look at the driver code, you should find somewhere a list of the supported PHYs.
For the uCOS / Interniche drivers, you will find them in the alt_tse_phy_add_profile_default() function in altera/*/ip/altera/triple_speed_ethernet/lib/sopc_builder/altera_triple_speed_ethernet/HAL/src/altera_avalon_tse.c . On my installed version (11.1) here is the list I have: [list][*]Marvell 88E1111[*]Marvell 88E1145[*]National DP83865[*]National DP83848C[/list] The National DP83865 is a gigabit PHY, but you should check first whether support for the PHY has been ported to the uCLinux driver. Or maybe uCLinux has a unified PHY driver architecture, independent from the MAC driver? If a uClinux specialist is around...
