MHahn4's avatar
MHahn4
7 years ago
Timing Constraints for Cyclone 10GX PHY Interlaken
I'm trying to run the PHY transceivers on a Cyclone 10GX in Interlaken mode.
While synthesising, there appears a "Timing requirements not met" critical warning. The problematic paths are for the following clocks:
unitname|xcvr_native_a10_0|rx_coreclkin
unitname|xcvr_native_a10_0|rx_pma_clk
unitname|xcvr_native_a10_0|tx_coreclkin
unitname|xcvr_native_a10_0|tx_pma_clk
I suppose there are some timing constraints missing? The only information about the timing constraints I could found, is to add
derive_pll_clocks -create_base_clocks
to the sdc file. But this doesn't solve the problem but adds another warning:
"Warning(332157): The base clock assignment for generated clock unitname|xcvr_native_a10_0|g_xcvr_native_insts[0].twentynm_xcvr_native_inst|twentynm_xcvr_native_inst|inst_twentynm_pcs|gen_twentynm_hssi_tx_pld_pcs_interface.inst_twentynm_hssi_tx_pld_pcs_interface|pld_tx_clk cannot be derived"
Can you please give me a hint, how the required timing constraints have to look like?
  • Hi,
    Along with derive_pll_clocks, I think to mention create_clock constraint for input reference clock(s) as well.
    create_clock -name {pll_refclk0} -period 10  [get_ports {pll_refclk0}]
    here, pll_refclk0 is the input clock port in the top module and 10 is 10ns (ie 100MHz input clock).
    With Regards,
    HPB
    • MHahn4's avatar
      MHahn4
      I did that already and the two input clocks are detected wth the correct frequency during synthesis.
      That's my full sdc-file:
      create_clock -name {CLK_100MHz} -period 10.000 -waveform { 0.000 5.000 } [get_ports {CLK_100MHz}]
      derive_pll_clocks
      create_clock -name {~ALTERA_CLKUSR~} -period 10.000 -waveform { 0.000 5.000 } { ~ALTERA_CLKUSR~~ibuf|o }
  • Do you still observe any other warnings. Basically, you only need to create clocks for the reference clock and pll clocks and it should be sufficient.
    Nathan
  • MHahn4's avatar
    MHahn4
    Yes. I've even tried a minimal design with loop back on the parallel data and only the three IP Cores (PHY, ATX-PLL, ResetController), but the timing errors still exist.
  • Hie,
    In that case, could you send you attach your design achieve (.qar) for me to check what is causing the timing error. Also, do advice which Quartus version being used.
    Nathan
  • Hie,
    Could you send me your simplified design achieve (.qar) for me to check what is causing the timing error. Also do advice which quartus version being used.
    Nathan
