MHahn4
7 years agoTiming Constraints for Cyclone 10GX PHY Interlaken
Hi, I'm trying to run the PHY transceivers on a Cyclone 10GX in Interlaken mode. While synthesising, there appears a "Timing requirements not met" critical warning. The problematic paths are for th...
Nathan_R_Intel
Contributor
7 years agoDo you still observe any other warnings. Basically, you only need to create clocks for the reference clock and pll clocks and it should be sufficient.
Nathan
