MHahn4
7 years agoTiming Constraints for Cyclone 10GX PHY Interlaken
Hi, I'm trying to run the PHY transceivers on a Cyclone 10GX in Interlaken mode. While synthesising, there appears a "Timing requirements not met" critical warning. The problematic paths are for th...
Nathan_R_Intel
Contributor
6 years agoHie,
Could you send me your simplified design achieve (.qar) for me to check what is causing the timing error. Also do advice which quartus version being used.
Nathan
