MHahn4
7 years agoTiming Constraints for Cyclone 10GX PHY Interlaken
Hi, I'm trying to run the PHY transceivers on a Cyclone 10GX in Interlaken mode. While synthesising, there appears a "Timing requirements not met" critical warning. The problematic paths are for th...
Nathan_R_Intel
Contributor
7 years agoHie,
In that case, could you send you attach your design achieve (.qar) for me to check what is causing the timing error. Also, do advice which Quartus version being used.
Nathan
