PPham3
7 years agoPCIe SRIOV Avalon Stream Gen 3 automatically generate locked read request
Hi all,
I have a problem with PCIe SRIOV avalon stream. I used SRIOV example design but tried to take the tx stream and rx stream out of the APP function. When I get those signal to signaltap. I noticed that some unwanted packet just streaming down through rx stream though the sw did not write or read anything. The packet format look like a locked read request( 8 lsb bits are 0x01h). Is this issue happens to anyone? How to get it work? Thanks.
You need APPS in order to make your design fully function. Without the APPS, the Host should still detect end points, and I don't aware any specify signal need to be connected.
Regards -SK
