PPham3
8 years agoPCIe SRIOV Avalon Stream Gen 3 automatically generate locked read request
Hi all, I have a problem with PCIe SRIOV avalon stream. I used SRIOV example design but tried to take the tx stream and rx stream out of the APP function. When I get those signal to signaltap. I not...
- 8 years ago
You need APPS in order to make your design fully function. Without the APPS, the Host should still detect end points, and I don't aware any specify signal need to be connected.
Regards -SK
PPham3
8 years agoI made a mistake. It was not a read req message, it's type just appears to be broadcast message from root complex. Just dont know why this message is automatically sent down.
By the way, when I use the hard ip only, pcie is not detected through lspci from linux. Everything works when using example design, anyone faces this problem?
