PPham3
8 years agoPCIe SRIOV Avalon Stream Gen 3 automatically generate locked read request
Hi all, I have a problem with PCIe SRIOV avalon stream. I used SRIOV example design but tried to take the tx stream and rx stream out of the APP function. When I get those signal to signaltap. I not...
- 8 years ago
You need APPS in order to make your design fully function. Without the APPS, the Host should still detect end points, and I don't aware any specify signal need to be connected.
Regards -SK
PPham3
8 years agothe reason why I do not want to use the APPS is to generate 4 PFs. at this point, the APPS is not supported (maximum 2 PFs for the APPS).
Still many thing to work since when I generate 2 PFs via example design, each PF has 8 VFs. The linux lspci can detect 1 PF and full 8 VFs, still one more PF missing. Is there any special signal that must be connected to make this design work
Thanks so much, SK Lim.
