PPham3
8 years agoPCIe SRIOV Avalon Stream Gen 3 automatically generate locked read request
Hi all, I have a problem with PCIe SRIOV avalon stream. I used SRIOV example design but tried to take the tx stream and rx stream out of the APP function. When I get those signal to signaltap. I not...
- 8 years ago
You need APPS in order to make your design fully function. Without the APPS, the Host should still detect end points, and I don't aware any specify signal need to be connected.
Regards -SK
SengKok_L_Intel
8 years agoAnyhow, you need the APPS to process the Memory read/Memory write and create the completion TLP. You can use the APPS in the example design to modify or update based on your design requirement. Or you can create your own APPS. It does not make sense to left the Avalon ST unconnected.
Regards -SK Lim
