PPham3
8 years agoPCIe SRIOV Avalon Stream Gen 3 automatically generate locked read request
Hi all, I have a problem with PCIe SRIOV avalon stream. I used SRIOV example design but tried to take the tx stream and rx stream out of the APP function. When I get those signal to signaltap. I not...
- 8 years ago
You need APPS in order to make your design fully function. Without the APPS, the Host should still detect end points, and I don't aware any specify signal need to be connected.
Regards -SK
PPham3
8 years agoHi SK Lim,
I did not check LTSSM signal. Was that signal meaningful for simulation only?
Still can not bring PCIe up without the APPS part? could you please give me a hint about connection? what the APPS really does to make this design work?
