18 years ago
How Can I set up DMA operation with my own PC software application?
Hi All:
I want to re-use the pcie_highperformancedesign example provided by the Arria GX Development Kit. Now I am confused with the PC software application altpcie_demo.exe. :confused:
I am trying to control FPGA to initiate dma read and write operation just like altpcie_demo does with my own PC software application but failed.
Firstly, I used Jungo Windriver to generate a pcie driver. With the API functions provided by the driver I can access(R/W) configure registers ,memory bar 1:0(the syncram) and bar2(dma control registers).
Secondly, I creat a Read Descriptor Table--Header+2 Descriptors and set data(Length,Ep mem addr, RC mem addr)for desciptors. The header has four dw(DW0,DW1,DW2,DW3). For DMA Read, I set DW0=0x00040002,DW1=0,DW2=addr of header,DW3=0x1. Then I write DW0 to Bar2+0x10,DW1 to Bar2+0x14,DW2 to Bar2+0x18,DW3 to Bar2+0x1c.
My first question: Where(mem addr) can I poll the RCLast value to indicate the completion of DMA read?:confused:
Thirdly, I want to transfer the DMA Read data back to PC. I creat a Write Descriptor Table--Header+2 Descriptors.In each descriptor, I set PC mem addr for write back data and addr of EP mem correctly .The header has four dw(DW0-DW3). For DMA Write, I set DW0=0x00050002,DW1=0,DW2=addr of Header,DW3=0x1. Then I write DW0 to Bar2+0x0,DW1 to Bar2+0x4,DW2 to Bar2+0x8,DW3 to Bar2+0xc.
At the end, I checked the write back data and found that the write back data are all zeros.It seems like that the FPGA does nothing at all.:confused:
What are the detailed steps I should follow to set up the DMA operation correctly? I read the pci express compiler doc but didn't get enough information about software application.
Thanks a lot for any help.
