18 years agoHow Can I set up DMA operation with my own PC software application?
Hi All: I want to re-use the pcie_highperformancedesign example provided by the Arria GX Development Kit. Now I am confused with the PC software application altpcie_demo.exe. :confused: I a...
18 years agoHmm....You might not be doing anything wrong, this all might be 'features' of the chaining DMA hardware.
Whether there is actually anything behind the BAR0 is controlled by the USE_RCSLAVE Verilog generic on the altpcierd_example_app_chaining module in the example design. Depending on which version of the PCIe compiler you are using this may be set to either 0 or 1 by default. You can change it to a 1 and recompile your design to enable the memory behind BAR0. When USE_RCSLAVE == 0 reads to BAR0 will not generate a completion on the PCIe link. The Root Complex (motherboard chipset) will timeout and probably return all FF's to the CPU. Now the .sof file that comes with the dev kit should have this set to a 1, so the memory should be there. But... I think the hardware may not respond completely correctly to a single byte read. The completion would probably still be for a Dword (4 bytes). The root complex may not like this and still return all FF"s to the CPU. Even though I'm not a software guy, with a little help from Google it looks like the readb() function you are using is just a single byte read. So if your design has USE_RCSLAVE == 1 (like the development kit .sof), I suggest trying to use writel() and readl() instead of writeb() and readb(), to see if that works for accesses to BAR0. Now as far as accesses to BAR2 go, it turns out those registers are write-only. The PCIe Compiler User Guide is just plain wrong on that. So reads to those will fail. The chaining DMA was designed to provide all of it's status through interrupts and writes to the host memory. Those registers are also never changed by the hardware so they always have the same value that was written by software. So there was no real functional need to have read-back, you just have to trust the hardware. Though I admit read-back would be nice for the "trust but verify" mindset. :)
