16 years ago
dsp buider using image processing toolbox
i am using dsp builder to generate hdl code..is it necessary to make simulink model using only altera dsp builder block set...i want to ask can i use image procesing toolbox to make simulink model and then use in dsp builder
    only DSP Builder blocks will generate synthesizable code to target Altera FPGAs. you can use other Simulink blocks as source/sink for DSP Builder systems.
    thanks for your reply..while designing simulink model can i use COMMON simulink blocks like ADD and SUB between the DSP BUILDER BLOCKS
    two more doubts sir:
    1.which block should i use for function x^y...where x and y are both input and y is fractional
    2.will there be problem if i use DSP builder blocks and ADVANCED DSP builder blocks together in a model...actually i want constant value which is in fraction..i didn't get any block from DSP builder library so i took block from ADVANCED lib
    3.from where i can get license for DSP BUILDER 9.0...and how
    1. variable "fractional root" is most probably not available, it's very complex in hardware.
    3. Just buy a license from Altera.
