16 years agodsp buider using image processing toolbox
i am using dsp builder to generate hdl code..is it necessary to make simulink model using only altera dsp builder block set...i want to ask can i use image procesing toolbox to make simulink model an...
16 years agoright, you'll need to use the adder from the DSP Builder library.
