16 years agodsp buider using image processing toolbox
i am using dsp builder to generate hdl code..is it necessary to make simulink model using only altera dsp builder block set...i want to ask can i use image procesing toolbox to make simulink model an...
16 years agotwo more doubts sir:
1.which block should i use for function x^y...where x and y are both input and y is fractional 2.will there be problem if i use DSP builder blocks and ADVANCED DSP builder blocks together in a model...actually i want constant value which is in fraction..i didn't get any block from DSP builder library so i took block from ADVANCED lib 3.from where i can get license for DSP BUILDER 9.0...and how
