16 years agodsp buider using image processing toolbox
i am using dsp builder to generate hdl code..is it necessary to make simulink model using only altera dsp builder block set...i want to ask can i use image procesing toolbox to make simulink model an...
16 years agoonly DSP Builder blocks will generate synthesizable code to target Altera FPGAs. you can use other Simulink blocks as source/sink for DSP Builder systems.
