16 years agodsp buider using image processing toolbox
i am using dsp builder to generate hdl code..is it necessary to make simulink model using only altera dsp builder block set...i want to ask can i use image procesing toolbox to make simulink model an...
16 years agothanks for your reply..while designing simulink model can i use COMMON simulink blocks like ADD and SUB between the DSP BUILDER BLOCKS
