DDR2 clock from PLL out
I am using Arria ii gx FPGA in Nios processor.altmemphy IP and our board main clock is 50 mhz
i want to know about interfacing between DDR2 clock to FPGA
my customize board connected the DDR2 clock with the differential pair pin AJ16 and AJ15.
My question is about the PLL dedicated pin how to create or assign dedicated pin in my top level design
Nome
- EBERLAZARE_I_Intel
In Quartus, you can open the Assignments > Pin Planner.
For pin out you may find your board:
Was my previous answer helpful to you? Do you have any further questions?
- nome
Hello.
Thanks for your reply.
Not helpful .....!
My simple question is: which PLL out for DDR2 differential clock do I have to use? In our case, the Arria II GX is using pin AJ16 and AJ15 for theDDR2 clock and assigning PLL C0 and FPGA main clock is 50mhz and PLL C0 100mhz DDR IP Refclk.
during compilation critical warnings occurring
Warning(15899): PLL"nios_cpu:inst0_nios_cpu|lms_ctr:lms_ctr_inst0|lms_ctr_ddr2_1:ddr2_1|lms_ctr_ddr2_1_controller_phy:lms_ctr_ddr2_1_controller_phy_inst|lms_ctr_ddr2_1_phy:lms_ctr_ddr2_1_phy_inst|lms_ctr_ddr2_1_phy_alt_mem_phy:lms_ctr_ddr2_1_phy_alt_mem_phy_inst|lms_ctr_ddr2_1_phy_alt_mem_phy_clk_reset:clk|lms_ctr_ddr2_1_phy_alt_mem_phy_pll:half_rate.pll|altpll:altpll_component|altpll_mto3:auto_generated|pll1" has parameters clk2_multiply_by and clk2_divide_by specified but port CLK[2] is not connected
how possible assign? In SDC file
please help us
First thing you need to check your board schematics on the available pins and the exact clock pins of your device, what is your part number of your device?
You need to verify the functionally of the pins in the pin out:
Once that done, open Quartus, you can open the Assignments > Pin Planner, and select the specific "CLK" pins that was reported you have in your top level, and assign it accordingly in the "Location" tab in Pin Planner.
Once done, you can close the Pin Planner and double check in your Assignment Editor, if done correctly you should see a green "tick" on the specific "CLK" pins that you have assigned.
Do you have further questions?
- nome
Hello
How to remove this warnings !
Warning (15899): PLL "nios_cpu:inst0_nios_cpu|lms_ctr:lms_ctr_inst0|lms_ctr_pll_0:pll_0|lms_ctr_pll_0_altpll_sgc2:sd1|pll7" has parameters clk2_multiply_by and clk2_divide_by specified but port CLK[2] is not connected
Nome
You need to locate the CLK[2] in your Pin Planner in Quartus, then assign that pin to location based on your schematics' Clock Pin.
- nome
The pin assignment can be made in Pin Planner, can you screenshot your pin planner.?
- nome
From your Quartus error and the "node name" in Pin Planner it is seem to be mismatch, please check the exact clock name in your that is defined in your top_level.v or top_level.qsys. That clock name should be the clock pin that you assign the PIN_F17. in Pin Planner.
FYI, I will be out until Christmas, and I will get back to you when I am back. We apologies for the inconvenience, I appreciate your patience.
- nome
Thank you for your reply.
I have checked many times, and the "node name" and PIN_17 has the exact same name because SPI and UART in the Nios ii processor are working perfectly.
However, whenever I add the PLL output connected to the DDR2 IP clock, critical warnings occur.
Thanks, Nome
Can you get me the full error list? I think there are some error related to the error you mentioned.
Anyway, I recommend that you could port over from this design to your device, it has the DDR and PPL connection in place:
Do you have any further update?
- nome
Hello
Thanks for your Comments
Warning (15899): PLL "nios_cpu:inst0_nios_cpu|lms_ctr:lms_ctr_inst0|lms_ctr_ddr2_1:ddr2_1|lms_ctr_ddr2_1_controller_phy:lms_ctr_ddr2_1_controller_phy_inst|lms_ctr_ddr2_1_phy:lms_ctr_ddr2_1_phy_inst|lms_ctr_ddr2_1_phy_alt_mem_phy:lms_ctr_ddr2_1_phy_alt_mem_phy_inst|lms_ctr_ddr2_1_phy_alt_mem_phy_clk_reset:clk|lms_ctr_ddr2_1_phy_alt_mem_phy_pll:half_rate.pll|altpll:altpll_component|altpll_mto3:auto_generated|pll1" has parameters clk2_multiply_by and clk2_divide_by specified but port CLK[2] is not connected
Warning (15899): PLL "nios_cpu:inst0_nios_cpu|lms_ctr:lms_ctr_inst0|lms_ctr_pll_0:pll_0|lms_ctr_pll_0_altpll_ecm2:sd1|pll7" has parameters clk1_multiply_by and clk1_divide_by specified but port CLK[1] is not connectedI am not understand why these above warnings occurs?
Nome
