DDR2 clock from PLL out
Do you have any further update?
Hello
Thanks for your Comments
Warning (15899): PLL "nios_cpu:inst0_nios_cpu|lms_ctr:lms_ctr_inst0|lms_ctr_ddr2_1:ddr2_1|lms_ctr_ddr2_1_controller_phy:lms_ctr_ddr2_1_controller_phy_inst|lms_ctr_ddr2_1_phy:lms_ctr_ddr2_1_phy_inst|lms_ctr_ddr2_1_phy_alt_mem_phy:lms_ctr_ddr2_1_phy_alt_mem_phy_inst|lms_ctr_ddr2_1_phy_alt_mem_phy_clk_reset:clk|lms_ctr_ddr2_1_phy_alt_mem_phy_pll:half_rate.pll|altpll:altpll_component|altpll_mto3:auto_generated|pll1" has parameters clk2_multiply_by and clk2_divide_by specified but port CLK[2] is not connected
Warning (15899): PLL "nios_cpu:inst0_nios_cpu|lms_ctr:lms_ctr_inst0|lms_ctr_pll_0:pll_0|lms_ctr_pll_0_altpll_ecm2:sd1|pll7" has parameters clk1_multiply_by and clk1_divide_by specified but port CLK[1] is not connected
I am not understand why these above warnings occurs?
Nome
