drbarryh's avatar
drbarryh
3 months ago
Correct way to configure the RGMII input and output pins on a MAX10 FPGA
Greetings ALTERA Expetrs,
I am using an ALTERA Triple Speed Ethernet IP core configured n MAC only mode, which talks to a MARVELL 88E1111 PHY. Actually for this example i am using an ALTERA MAX10 10M50-C Development kit. I am having trouble understanding exactly HOW to configure the DDR RGMII input and output pins.
After instantiating the Triple Speed Ethernet IP in a top level System Verilog file and connecting up Avalon MM, Avalon Tx/Rx ST interfaces etc, and connecting up clocks and resets, do i need to to connect up my RGMII DDR outputs using altddio_out IP and my RGMII DDR inputs to FPGSA pins using altddio_in IP blocks ?
This is how i am thinking i need to connect my DDR RGMII FPGA pins up to my Triple Speed Ethernet RGMII tx in and rx in busses on the IP:
Connect the TX Clock output :
altddio_out #(.width(1), .INTENDED_DEVICE_FAMILY("max10"))
altddio_out_a_txc (.outclock (clk_125MHz),
  .datain_h (1'b1),
 .datain_l (1'b0),.dataout (RGMII_ETH_TXC), // TSE clock TX PORT A
 .oe (1'b1),
 .outclocken (1'b1),
.aclr (1'b0),
.aset (1'b0)
Connect the RGMI TX data outputs :
altddio_out #(
.width(4),
) altddio_out_a_txd (
.outclock (clk_125MHz), // 125 MHz Transmit clock for RGMII
.datain_h (rgmii_out_ddr), // rising edge
.datain_l (rgmii_out_ddr), // falling edge
.dataout (rgmii_out),
.aclr (1'b0),
.aset (1'b0),
.oe (1'b1),
.outclocken (1'b1)
Where in the above code rgmii_out wires are going to FPGA DDR RGMI TX output pins, and rgmii_out_ddr is from the Triple speed IP core.
For the RX side for the INPUT DDR RGIM Rx data bus:
altddio_in #(.width(4), .INTENDED_DEVICE_FAMILY("max10"))  altddio_in_a_rxd (
.inclock (RGMII_ETH_RXC),
.datain (rgmii_in),
.dataout_h (rgmii_rxd),
.dataout_l (/* unused */)
Do these sort of DDR interface IP instantiations looks correct ?
All help gratefully received !
Thanks, Dr Barry H
  • FvM's avatar
    FvM
    Hi Barry,
    not sure why you're instantiating dedicated DDR IO. TSE IP in RGMII mode already interfaces to DDR RX and TX data.
    Frank
  • FvM's avatar
    FvM
    Hi Barry,
    Frank
    • drbarryh's avatar
      drbarryh
      Hi Frank, thanks for your reply. Yes i figured that out with the error messages i received from Quartus after i tried instantiating my own DDR I/Os ! The error message was saying that the TSE already instanced some GPIO Lite DDR I/Os (the MAX10 equivalent). I just am not that familiar with the MAX10 FPGA's or the TSE, and just getting back into Quartus as well after many years using Vivado and Xilinx FPGAs !
      But i am getting better gradually !
      Now i have managed to reconstruct the ALTERA MAX 10 example design using the following approach :
      Create a new project -> use the par file: max10tse_q_18_0_std.par from the MAX10 TSE Example design, in Quartus 2018 it fails to reconstruct the Qsys platform because of a lot of missing IPs (like the packet gen, packet mon etc.). But then i tried it from the  max10tse_q_17_0_std.par version, then tried to do an update to Quartus 2018 and luckily that works and gets me all the missing Qsys IPs.
      I then tried to compile that project in Quartus 2018 and hey presto it compiled ok and met timing! Great progress i thought ! I connected a Windows 10 PC to my dev kit using an Ethernet cable and programmed in its MAC address as the DST address for the Tests. Also tried the same tests using a UBUNTU PC. But i get the same failed results at the moment.
      But when i try out the TCL scripts in the sc_tcl sub directory and run them, the TEST_MAC_LB "1000M" and  TEST_MAC_PHY_LB "1000M" commands both fail, after i of course run the source main.tcl script.
      I am using a ALTERA MAX10 10M50-C dev kit as my base for these tests. In the stats_chk command results i see all frames transmitted (100000) but 0 frames are being received.
      Any ideas on what is still going wrong and a solution would be most appreciated ! I am stuck now :)
      Thanks, Dr Barry H
