Correct way to configure the RGMII input and output pins on a MAX10 FPGA
Hi Barry,
not sure why you're instantiating dedicated DDR IO. TSE IP in RGMII mode already interfaces to DDR RX and TX data.
Frank
Hi Frank, thanks for your reply. Yes i figured that out with the error messages i received from Quartus after i tried instantiating my own DDR I/Os ! The error message was saying that the TSE already instanced some GPIO Lite DDR I/Os (the MAX10 equivalent). I just am not that familiar with the MAX10 FPGA's or the TSE, and just getting back into Quartus as well after many years using Vivado and Xilinx FPGAs !
But i am getting better gradually !
Now i have managed to reconstruct the ALTERA MAX 10 example design using the following approach :
Create a new project -> use the par file: max10tse_q_18_0_std.par from the MAX10 TSE Example design, in Quartus 2018 it fails to reconstruct the Qsys platform because of a lot of missing IPs (like the packet gen, packet mon etc.). But then i tried it from the max10tse_q_17_0_std.par version, then tried to do an update to Quartus 2018 and luckily that works and gets me all the missing Qsys IPs.
I then tried to compile that project in Quartus 2018 and hey presto it compiled ok and met timing! Great progress i thought ! I connected a Windows 10 PC to my dev kit using an Ethernet cable and programmed in its MAC address as the DST address for the Tests. Also tried the same tests using a UBUNTU PC. But i get the same failed results at the moment.
But when i try out the TCL scripts in the sc_tcl sub directory and run them, the TEST_MAC_LB "1000M" and TEST_MAC_PHY_LB "1000M" commands both fail, after i of course run the source main.tcl script.
I am using a ALTERA MAX10 10M50-C dev kit as my base for these tests. In the stats_chk command results i see all frames transmitted (100000) but 0 frames are being received.
Any ideas on what is still going wrong and a solution would be most appreciated ! I am stuck now :)
Thanks, Dr Barry H
