Can nPERST pins be used as PCIe reset if Intel® Stratix® 10 PCI Express* Hard IP is used as Root Complex?
According to the Pin Connection Guildline, Pin Functions of nPERST[L,R][0:2] are input or I/O. When you do not use this pin as the fundamental reset, you can use this pin as a user I/O pin.
Is it mean when I use this pin as fundamental reset, this pin is input? If I use the PCIe hard IP as PCIe Root Complex, do I need to assign a GPIO as fundamental reset?
Hi ,
I will share you one design , I hope it is publicly available with Root port .
Use the below as reference
Kindly have reference.
https://rocketboards.org/foswiki/Projects/Stratix10PCIeRootPortWithMSI
- Rahul_S_Intel1
>> Input
If I use the PCIe hard IP as PCIe Root Complex, do I need to assign a GPIO as fundamental reset? >> NO
Kindly find the explanation
When the PCIe HIP on a side (left or right) is enabled, the nPERST pins on that side cannot be used as general-purpose I/Os (GPIOs). In this case, connect the nPERST pin to the system PCIe nPERST signal to ensure that both ends of the link start link-training at the same time.
- Wujun
So if I use the PCIe HIP and use S10 as Root Complex (system side), which pin can be connected to the End Point (device side) PERST#? Because as a RC, S10 need a output PCIe PERST#, but the S10 nPERST pin is an input signal.
- Rahul_S_Intel1
Hi ,
Sorry to keep you to wait this much long , I have done my research, kindly find the details.
When the PCIe HIP , setting is made as root port , the pin_perst configured as input , the same I have verified with Stratix 10 example design.
Kind find the attached screen shot for PCIe HIP for your reference which I took from the example design.
- Wujun
Hi ,
The pin_perst configured as input?
->From the screen shot, pin_perst is just an internal signal, but I need a pin name which can be found in the Intel® Stratix® 10 Device Family Pin Connection Guidelines. Do you mean when S10 is setting as root port, nPERST pin can be used and be configured as output?
- Rahul_S_Intel1
Hi ,
The pin_perst configured as input ?
>> Yes
>> Yes you are right, it is an internal signal . This internal signal pin_perst of each hard IP instance to the corresponding nPERST pin of the device. ( Reference pag no: 48) , also attaching the screen shot also for easy reference.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_s10_pcie_avst.pdf
>> No
- Wujun
So how to control the PCIe reset? In this case, both Root port and End port are input signals. Connect a FPGA I/O pin with S10 nPERST and End Port PCIe reset?
- Rahul_S_Intel1
Hi ,
- Wujun
Thank you. Refer to the schematic, an I/O is connected to the End Port PCIe reset.
- Rahul_S_Intel1
- Rahul_S_Intel1
- Rahul_S_Intel1
Hi ,
Kindly let me know if you need further assistance
