Wujun
6 years agoCan nPERST pins be used as PCIe reset if Intel® Stratix® 10 PCI Express* Hard IP is used as Root Complex?
Hello, According to the Pin Connection Guildline, Pin Functions of nPERST[L,R][0:2] are input or I/O. When you do not use this pin as the fundamental reset, you can use this pin as a user I/O pin. ...
- 6 years ago
Hi ,
I will share you one design , I hope it is publicly available with Root port .
Use the below as reference
Kindly have reference.
https://rocketboards.org/foswiki/Projects/Stratix10PCIeRootPortWithMSI
Wujun
6 years agoThank you. Refer to the schematic, an I/O is connected to the End Port PCIe reset.
